Hello I am installing BI and DS on a new pc and following the you tuber "The Hook Up" and have 2 questions regarding the instructions within the video.
1. He sets up hd and sd streams, the sd is for 24 hour recording and sd for hi res capture. After using this setup for a couple of days I am seeing my ssd space filling up quickly with low res 24 hr recordings and questioning why am I doing this? I am installing DS to reduce the false notifications and increase identification accuracy alerting to 80% or better and use BI to automate some functions, 24 hr recording to my way of thinking isnt providing much if any value. Put another way I am content with capturing events I consider important and leave the rest alone. Also if I choose to forgo the 24 hr sd recording I can increase the image quality of my desktop and web interface. Any thoughts, experience, feedback?
2. In AI Tool, which is used to define what you want DS to look for, there is a "Trigger URL" which sends a trigger command to the camera to start recording when an event occurs. The question I have is this...Is the URL a standard format meaning it works with all IP cameras or does it vary by manufacturer? I have Amcrest and Annke, the latter I think I have solved as the guy in the video also uses Annke, but I am still trying to find any info for Amcrest. Ive done searches for "rtsp url trigger" and variations with no luck. Any advice appreciated.
Thank you.
Thank you.
