mat200
- Jan 17, 2017
- 18,514
- 31,045
I sent him a message and will await his response. Thanks
FYI - here is an example of a model I would consider for a better 8MP coax camera .. this is a varifocal model, so you can adjust the FOV and thus pixels on target as needed.
There are also non=varifocal, in which case I would look at 3.6mm lens or stronger .. ( 6mm if you want to watch the street for example )
note: this is from searching Dahua's international website .. not the USA version ..
HAC-HDW2802T-Z-A
4K Starlight HDCVI IR Eyeball Camera
Starlight, 120dB True WDR, 3DNR
Max. 4K resolution
HD/SD switchable
Audio in interface, built-in mic
3.7-11mm motorized lens
Max. IR length 60m, Smart IR
IP67, DC12V±30%
If you need better low light performance, then perhaps this model .. 4MP and a 1/1.8" sensor .. ( also a varifocal )
HAC-HDW2402T-Z-A
4MP Starlight+ HDCVI IR Eyeball Camera
Of course you can pick on good 4MP w/a 1/1.8" sensor ( better for low light image capture ) and one 8MP w/a 1/1.8" sensor ( better for day time image capture as you have more resolution )
Many ways to mix and match - and it could be that you just start out adding one better coax camera to your kit ..
