PSPCommOp Getting the hang of it Jun 17, 2016 688 92 Northeastern PA Aug 13, 2016 #1 My PC is just for recording, with the occasional browsing to IPCamTalk while I'm adjusting/tinkering with some settings. Wondering what everyone uses for antivirus on their PC's, if anything.
fenderman Staff member Mar 9, 2014 36,891 21,416 Aug 13, 2016 #2 You will be fine with the built in av...or if you wish I use norton on some machines...make sure you exclude BI from the AV.
D Del Boy Getting comfortable Mar 19, 2015 2,723 294 UK - England Aug 13, 2016 #3 I massively rate Avast Free. Switched from AVG a while back and haven't looked back since.
PSPCommOp Getting the hang of it Jun 17, 2016 688 92 Northeastern PA Aug 13, 2016 #4 Del Boy said: I massively rate Avast Free. Switched from AVG a while back and haven't looked back since. Click to expand... Any particular reason why? Just curious. I've heard of AVG but not Avast.
D Del Boy Getting comfortable Mar 19, 2015 2,723 294 UK - England Aug 13, 2016 #5 Less resource usage, better interface. I had an issue with AVG missing a virus which I know they all can do but that swung it for me. http://uk.pcmag.com/avast-free-antivirus-2015/37196/review/avast-free-antivirus-2016 http://www.expertreviews.co.uk/software/internet-security/1401985/avast-free-antivirus-2015-review Full scan is slow... oh well, I don't normally sit there and wait for that, I schedule it for lunch. Generally comes top or 2nd for free AV.
PSPCommOp Getting the hang of it Jun 17, 2016 688 92 Northeastern PA Aug 13, 2016 #6 Del Boy said: Less resource usage, better interface. I had an issue with AVG missing a virus which I know they all can do but that swung it for me. http://uk.pcmag.com/avast-free-antivirus-2015/37196/review/avast-free-antivirus-2016 http://www.expertreviews.co.uk/software/internet-security/1401985/avast-free-antivirus-2015-review Full scan is slow... oh well, I don't normally sit there and wait for that, I schedule it for lunch. Generally comes top or 2nd for free AV. Click to expand... Nice i'll look into it, thanks! If I use Remote Access in Windows 10, would the AV affect anything with that?
