Banging Head. Dahua NVR5216-4KS2 4K NVR won't connect to Annke C800 or Dahua 4K cameras
AHDGUY
Sep 22, 2020
2
1
UK
I've been installing systems for a few years now, and I have one location where they have the above NVR, and recently purchased the Annke C800 which I saw recommended.
Firstly I can only view the streams via IE. Chrome or EGDE just shows a blank screen on the live view for both main and sub stream.
So I know I am getting a feed. The NVR, cameras and PCs are all connected to the same gigabit switch.
When I do a search on the NVR it finds the camera - click add, edit password and yet this still stays not connected
I've tried just about every combination of ONVIF settings and Private yet the Dahua just will not connect to the camera. (ONVIF enabled on the Annke)
There other Hikvison cameras connected, and other random makes, just not this one - any ideas?
Ok found the issue - when I added the camera from the device add button, the default for RTSP mode was 'custom' and needed to be 'self-adaption'
Hopefully help someone else out there...
Reactions: TonyR
