B54PRO-Z4E first impression
Better with 0 NR
Will suck on dark days and lower light levels
View attachment 232439 View attachment 232440
Yes indeed, that is looking a lot better, NR just kills these at the moment. Remind me what gain you have set? that is another things which seems to affect these more than most cameras, I would like to have mine on 30 but stick with 40 so it eases to transition when light fades. If you can manage the sharpness (off!) and NR also off or very low, the dark days might surprise you. Not S3 brightness but pretty good considering, it is one area these seem to do quite well, not consistent but there we are. They just do not like sharpening and NR, S3 will tolerate both without too many issues, I can only assume on the Pro's it screws with the auto processing/algorithm.
Reactions: JDreaming
Thats 50 gain and 50 iris.
Its also back to my 30FPS
Because it looks into those bushes across the street and the way the sun is this time of year, makes it tough lighting conditions
I rarely change Gain from default on most cameras (daytime) unless needed. 50 is default. Its fine on most cameras during the day unless I need to lighten or darken something
Now on that camera, its bright in the morning and much darker towards afternoon as shadows move in so I've left it at 50 to help the afternoon
OK, here is the thing, in the daytime you should be running gain as low as possible, this reduces ISO and in turn quality should significantly improve, potentially at least. Your mileage may vary of course, some will notice the quality more than others. If you have lots of light then potentially the improvement might be more marginal. You will see the biggest example at night if you push the gain (in turn ISO) up the image falls apart, detail degrades and bad things happen.
I will always try to run daytime gain sub 40, and sometimes 30 or less if I can manage it. You will get better quality output if you can go sub 40. Some of mine might even be running 20-30, this will force them into B&W/IR early but I am fine with that. During the night gain will almost always need to be 40-50+
Anyway, that is just my take, coming from the camera world, ISO is key and I want it low as possible at all times.
@bigredfish I would have a small virtual :lol: wager that you will see a nice change in daytime quality on the 54Pro if you knock gain down to 20-30 just for a test, of course it will darken the image somewhat but you have so much light there it should be fine. Pushing the ISO (gain) down will give you a cleaner image, with less digital 'interference' so to speak. Essentially it should bring the finer detail out in the image.
I will put my 54Pro ZE which covers a road on max zoom tomorrow and just make sure it still gives me good freeze motion, at the moment it is on around 50% zoom, possibly 60%. I do have one covering a door way with human traffic and that is OK, maybe not quite S3 level but pretty damn close, more like your first white SUV image than the next 5. For the record, I actually prefer the white suv image from the Pro, more natural look, the 5442 version of that vehicle looks over sharpened and processed, that could be personal preference. Granted the other images from the 5442 in those samples are clearly superior to the Pro. It's even more bizarre because you should be getting reasonably consistent images like the first one.
Re: the white SUV
You know the stuff on the side of the vehicle is actually reflection and not any type of artifact or noise right?
It took me a few seconds to figure out that was reflection of white trellis and house
Decided to have a cocktail and try some crazy shit - check out the Encode tab
Best nighttime image so far
View attachment 232488 View attachment 232487 View attachment 232486
View attachment 232490 View attachment 232491 View attachment 232492 View attachment 232493 View attachment 232494
Improvement from the ghost rider settings :rofl:
Whoa, look at the focus point! You need to walk on top of that block wall. How's your balance? Drink some coffee. You'll be fine.
In the future, I won't buy brand new cameras anymore. It was definitely a lesson learned.
A lesson learned doesn't mean much when the next new camera comes out and you want to get your hands on the new toy. I almost bought the B54PRO-Z4E and still thinking maybe I should give a try after you guys proving there are problems with this new camera that needs to work out first. It's difficult to control the impulse sometimes..... :lol:
Best to be cautious, I 'only' bought three to test the water :rofl::lmao: - turns out it was the deep end. :slap:
Dropping this in here since I was typing something similar as a reply elsewhere. No doubt a lot of this is common knowledge but anyway...
I have found it quite interesting to test the four camera variations I got recently, S3 turret, S3 bullet, 4K-T and of course the 54ProZE!
Still for critical monitoring the S3 bullet series is a clear winner, I am enjoying the 4K-T for its ability to give colour ID, there are times when you essentially need both. The S3 would give detail in B&W, whilst the 4K series could provide the colour of clothing or vehicle. Equally the S3 turret is a very tidy all in one solution, IR power is limited but it is a reliable option for day and night coverage.
There are still times when the 54Pro produces some great footage, mostly during the day but bizarrely it can shine at sunset or sunrise, even when it is quite dark. Not for long but there is a small window where I feel like it produces results that even the S3 or 4K couldn't match. But the window is small and once night falls the S3 and 4K would have it covered. Reminds me of some digital photo camera sensors I have tested in the past, equally they could produce some great detail at times, all be it with fine grain/noise.
This has been a good voyage of discovery for me, especially since I had not purchased a new camera since the 5442 series back in 2021. Similar to the digital camera world, some days you need a large sensor with 24 megapixels, on brighter days you will take 45 megapixels and benefit from good light! In other words, go buy some more cameras :lol:
This experience along with the 3449 TIOC PRO (which actually has a better image at least with the fixed lens) have convinced me that Dahua like so many others has gone full speed ahead on AI, bells n whistles, and managed cloud features (DoLynk) , and has either hit an optics or cost brick wall on IQ improvements
