I have a SD49225T-HN but I have some issues with external commands. I'm sending http commands from Blue Iris and I can change preset and change profile with out any problem.
I change preset with (-->login and ip + /cgi-bin/ptz.cgi?action=start&channel=0&code=GotoPreset&arg1=0&arg2=1&arg3=0 )
I change profile with (-->login and ip + /cgi-bin/configManager.cgi?action=setConfig&VideoInMode[0].Config[0]=0 )
But I cant get the focus or set the focus...
When I run these commands the only thing I get is "Error". Why doesent this work. Can anyone with a SD49225T-HN test and see if it works for them.
http://<ip>/cgi-bin/devVideoInput.cgi?action=getFocusStatus
http://<ip>/cgi-bin/devVideoInput.cgi?action=adjustFocus&focus=0.02&zoom=0
My software version for the unit is "2.422.0000.0.R.4.2510, Build Date: 2016-09-21"
