Anyone here tested the IPC-HDW4231EM-ASE?
Arjun
10,652
13,963
USA
IPC-HDW4231EM-ASE - Dahua Technology
Has Starlight :)
> 1/2.8” 2Megapixel progressive scan STARVISTM CMOS
> H.265&H.264 triple-stream encoding
> 50/60fps@1080P(1920×1080)
> Smart detection supported
> WDR(120dB), Day/Night(ICR), 3DNR,AWB,AGC,BLC
> Multiple network monitoring: Web viewer, CMS(DSS/PSS) & DMSS
> 2.8mm fixed lens (3.6mm,6mm optional)
> Built-in Mic
> Max. IR LEDs Length 50m
> Micro SD memory, IP67, PoE
Anyone has picture comparison of night vision? IPC-HDW4231EM-ASE vs IPC-HDW4231EM-AS
Someone mentioned better night vision
Doesn't have Starlight but seems to be decently priced,
It should be a Starlight. Has the same image sensor size (and megapixels) as the Starlight 4231/5231, plus the Starlight logo is on the page you linked to.
Reactions: Arjun
You're right, I don't recall seeing that starlight logo on their website at the time of originally checking.
Look at the minimum illumination. That is what will tell you how well it will perform at night without basing it on marketing terminology.
Reactions: Arjun
I'm looking forward to comparison snapshots. If anyone can post a review if they have the latest model, that'd be great. Thanks :)
Has Starlight :)
> Built-in Mic
Sorry, it took a little bit longer for me to test it and find convenient weather conditions for mounting and taking some snapshots with the cam. Iv'e been snowed under with work for the past four weeks.
If you need more information or snapshots, just ask...
Here's my review...
Reactions: weigle2 and Arjun
