I have a BI setup at my parents place running on a HP Elitedesk 800 G4, i5-8500, 16GB RAM, and a couple of NVME SSD's. There are 6 cameras connected; 5 Dahua and 1 Reolink, and the CPU utilisation is fine, typically ranging 12-16%.
I have a GPU lying around and was wondering if there was any benefit adding it to the PC. The GPU is from another HP elitedesk (ie as a std option), with p/n 923800-002. Here is a link to the gpu:
technologylocker.com.au
Would adding a gpu like this provide any benefit at all, ie would any processing be off loaded to it? Also, as the BI pc is headless, there would be no monitor connected up to its outpus, so I'm not sure whether it would still be doing anything?
Thanks for your help in advance.
HP AMD Radeon R7 430 2GB GDDR5 923800-002 Low Profile Graphics Card VG
Specifications Memory Size: 2 GB Connectors: DisplayPort,VGA Compatible Slot: PCI Express 3.0 x16 MPN: 923800-002 Chipset/GPU Model: AMD Radeon R7 430 Brand: HP Chipset Manufacturer: AMD Memory Type: GDDR5 Features: Small Form Factor (SFF) UPC: Does not apply Package Contents HP AMD Radeon R7...
