My alarm block looks like this:
NO1 C1 GND 1 2 GND
CTRL P GND 3 4 GND
My current setup is 12v 1 amp power supply (+) to alarm siren (+) and (-) from power supply to NO1 with (-) from siren to C1.
My specs sheet says it has 2 alarm outputs and 4 inputs. What I'm seeing is if I remove the pluggable alarm block from the top
and stick it into the bottom the siren will remain active (NC - Normally Closed) unless I click manual in the NVR settings to disable it.
If it's the same as NO2 and C2 it is NC and anything connected will be always on 12v.
I can potentially use this anyways such as to turn power off to an electric lock on a dog fence but I'm questioning how to change this
to a Normally Open or NO.
NO1 C1 GND 1 2 GND
CTRL P GND 3 4 GND
