ohliuw n3wb Aug 9, 2017 20 5 Sep 26, 2017 #1 What is the cheapest option to connect an existing BNC PTZ cam to (dahua) NVR? It's 1080p, and I want to be able to control the PTZ from the NVR. I found some axis video servers (e.g. 241s, 2400), but they do not seem to support 1080p. Thanks
fenderman Staff member Mar 9, 2014 36,891 21,416 Sep 26, 2017 #2 ohliuw said: What is the cheapest option to connect an existing BNC PTZ cam to (dahua) NVR? It's 1080p, and I want to be able to control the PTZ from the NVR. I found some axis video servers (e.g. 241s, 2400), but they do not seem to support 1080p. Thanks Click to expand... you would need an ahd nvr...forget it...try to sell it for whatever you can get for it and move on..
