I managed to brick my Foscam NVR by doing a firmware update, it stays at "Loading..." forever. The useless support just says I need to buy a new one since my is out of warranty, no options to debug or to try to fix just told to replace. After that experience I am not going to buy another Foscam NVR. I'd like to not replace all the cameras (FI9800XE) and I see that the Amcrest NV4108E-HS supports many camera types and hope that it is compatible with the 8 POE FI9800XE. The support at Foscam first said it supported ONVIF and would be compatible then said I needed to buy another Foscam NVR. A bit confused...
