I have a lorex system in a clients business and have attached 2 x IPC-HFW5241E-Z12E to be used as License Plate Cams. I know I need to access the web client to be able to adjust the shutter speed. Issue is when I connect it to the NVR is sets the IP as a local IP (10.0.0....) to the NVR and I can not access it. If I plug it into their POE switch on network then I can (192.168.0.108) . I understand that I could add a separate POE switch for these two cameras to access but didnt know if there was a way to access them when connected to the NVR. Just would be cleaner that way. Customer does not want us to use his current POE network switch. ALSO, if possible to help here also.... The two IPC-HFW5241E-Z12E cameras dont populate a preview screen on the NVR screen like all the other cams. See pic. They are 20 & 21.
