It may sound like I'm contradicting myself especially when I recently bashed about earlier 4K camera models (having a 1/2.5" Sensor). However, seeing that the more recent 4K models have garnered some attention, if you were given only two options and needed a focal length of 6mm or less --- IPC-HFW1831E (fixed lens with 2 IR lights, but no microSD card slot, tedious access to reset button) vs the IPC-HFW2831T-ZS (varifocal lens with 4 IR lights and microSD slot and easy access to reset button), what would be your top pick?
Both cameras supposedly have the same exact 1/1.8" sensor. Why is one f1.6 and the other f1.9 with differing lux ratings?
Technically, shouldn't both models perform similarly, assuming they are both set at the same focal lengths?
Cast Your Vote
Cast Your Vote
