3x2MP Multi-Sensor Network Camera+PTZ Camera PSDW5631S-B360
EMPIRETECANDY
IPCT Vendor
Nov 8, 2016
9,462
27,781
HONGKONG
A screen capture video of someone using the web interface of this camera would answer a lot of questions.
Also, will it appear as four cameras to the VMS? 2? 1? Depends on fisheye settings?
Is the PTZ sensor used as in a seamless manner to improve the quality when a user digital zooms and dewarps one portion of the fisheye composite view? So when you start zooming in on an area, it switches over to live PTZ image and auto-positions the PTZ cam at that spot?
It's not available yet, so its all assumptions. Looks like an awesome camera!
And if 3 X 2MP isn't quite enough for you, try the new 4 X 2MP version:
Multi-flex™ 4x2MP IP Camera – Dahua North America
Model Number: DH-IPC-PDBW5831N-B360
Series: 2MP, Dome, Enhanced Starlight, IK10, IP67, Network Cameras, Panoramic, Starlight
The Dahua DH-IPC-PDBW5831N-B360 Multi-sensor Dome Camera features four (4) 1/2.8-in. 2 MP Progressive-scan STARVIS™ CMOS Sensors each with a 2.7 to 12 mm motorized lens. Each sensor can be positioned and configured independently of the others allowing flexible, multi-directional video surveillance that replaces multiple single-sensor cameras and is ideal for monitoring large areas. The camera offers Wide Dynamic Range, a True Day/Night IR Cut filter, IP67 Ingress protection and operation in extreme temperatures to deliver superior images in all lighting and environmental conditions.
