34 inch monitor for BI server recommendations
TheE
Pulling my weight
Dec 8, 2018
180
115
TX
Would also like it to have built in speakers for the cameras audio. The finished install will have 4, 5, and 8MP cameras.
Thanks in advance for any recommendations!
I have a BenQ 3410R and love it. Don't get an MSI, all 3 that I've seen went bad within a year or so including mine.
Reactions: TheE
Thank you for your time with this input! Once more quick question if you can: what is needed to connect this monitor to a BI server so you can hear through the speakers what audio the cameras recorded?
All you need is to open up UI3 in a browser. Any smart TV that that has a newer web browser on it. Or TV plus an Amazon FireStick to make it smart will work. Before you purchase anything, try this out on your TV. Most of us have our BI computer set up as "headless", meaning the computer is stuffed away somewhere on a shelf and there is no monitor, keyboard or mouse connected to it. We use RDP or TeamViewer from another computer on our network to open up the BI GUI or to do computer maintenance. And, we use UI3 typically to view live stream or the recordings.
My vote is always for a Fire TV/Firestick - then any size you want - running UI3 on it through a web browser. Wireless so you can put it anywhere you want.
Reactions: CanCuba and TheE
Correct me if I'm wrong, but wouldn't it make more financial sense to go with a dedicated monitor? Especially that we'll have room for it.
I may have missed something, but I just checked, and TeamViewer is like $25 per month.
Reactions: Starglow
Most of us don't have a dedicated monitor for the BI computer.
TeamViewer only costs if you use commercially.
But most use RDP if you are on your own LAN and it is like you are sitting at the computer.
So for most of us it makes the most financial sense to not have a dedicated monitor and thus be able to place the BI computer anywhere you can get an ethernet cable to it and then remote into it if we need access to the computer or use the web browser UI3 option for daily viewing.
Reactions: mteky2 and TheE
